Upgraded master cylinder, crappy pedal now...
oldsmobile joe
2,067
3,053
mpls
Are you still running the blazer m/c with the caprice booster? Or did you change m/c with the caprice booster?
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
The caprice booster is the larger single diaphragm?
69hurstolds
8,198
17,600
Probably the actuating rod length changed a little after the booster change. That's my guess. Booster by itself either works or it does not. Unless you had a bad booster unit to begin with, then that's another story.
81_El_Homewrecker
170
That’s also possible. With the larger Blazer booster the pedal required more “effort” than the stock master/booster. With both new the pedal is firm but in a good way haha
