Re: Another Daily Driver
Heat range is only one step off. Reach sucks but it can't be anyworse than the old spark plug non-foulers. Motor is pretty much stock, so I really can't see it hurting much. I can't move the pipe that is causing the main problem. I would have to end up dumping the exhaust out the front, and that will be tough with the fuel pump and lower radiator hose in the way. I will change the header but only if absolutely necesarry. I haven't even heard the motor run yet, so there's a lot of things i'm just trying to get close enough to fire it.
