Vacuum Question seeking help !
garyizraw
13
Is that hose loose or is it plugged into the bottom plate of carb
The one in my first pic is loose and i need to see where it runs
the one in that last pic with the blue F fitting i believe that is running to the purge TVs or canister
airboatgreg
2,871
3,116
There is a hole in the carb under the TPS connector and a little to the right as I recall. Start engine and see if you can feel around for vauum
garyizraw
13
yeah that hole is exactly what im trying to figure out, before it had a hose on it and it withered in my hand so i got this new one to put on there but idk if it connects to anything or just stays free ?
Clone TIE Pilot
3,869
2,622
Galaxy far far away
It may be the port for the Vacuum sensor that should be mounted on the passenger side front inner wheel well.
garyizraw
13
I believe i know what your talking about and thats a smaller line that runs to the sensor right behind the blower motor? right
9,198
15,457
Just like with wires, a GM service manual would be one of the best sources to se how the lines are to running. Good chance an p/o might of change the routing of a few.
Clone TIE Pilot
3,869
2,622
Galaxy far far away
Yep, these cars are very prone to being screwed around with by POs that had no idea what they were doing.
WanaBa442
556
1,318
New England
Go here, scroll down till you find your year/engine model: https://www.autozone.com/repairguid...Diagrams/Vacuum-Diagrams/_/P-0900c1528005c9b2
