Hi all, long time no see but i am back! :lol: so the old gal developed a bit of an issue on me late last year, namely when i drive it work, about 25 miles, it always wants to die as im pulling into the lot, or whenever else it drops to an idle and i dont keep the RPMs up a little. It sometimes will do it on shorter drives too. It can be pretty hard if not impossible to re-fire after an episode, at least for an hour or so, then its fine again. Usually, if i floor the throttle it will start, but it doesnt want to idle. I admittedly am a bodyman, and by no means a mechanic so im perplexed. Could the fuel be getting to hot? should i change the lines, try a different filter, maybe a spacer? Ive also noticed a very high build up of pressure in the tank, to the point it makes the cap dance if i loosen it even after a short drive. So thats got me wondering if it is getting to much pressure to the float and flooding. Im wondering if i need a pressure regulator, or a carb spacer, or both. Thoughts opinions and request for any more info are appreciated!
