Very high front end issue
87monteSSMN
Nov 20, 2018
74
24
Yeah, I would agree they are wrong. It's so weird because the shocks removed were original GM I'm sure from 87. Tires have almost no wear, but date code on em is from 1995 and they are dry rotted pretty bad. Junk. Anything older than 5 years is usually junk anyway.
TomDisab
Nov 16, 2016
69
67
I bought a brand new 86 Monte SS, and it never sat up like that. It was even front and back, but not tilted up. The rear looks normal height but the front end looks a little higher than stock. Hmmm.
My '87 Aerocoupe with 852 miles on it last March. That's the way they sit.
9,619
12,711
Reactions: 8 users
8,234
17,712
Sad. I'd probably have to fix that if my car did that. I know that would bug me a little every time I saw it. I'm sure it doesn't affect the ride, plus MC wheel wells are kind of huge looking as it is, but still.
black_aerocoupe
106
46
Is there a reason the front end on this thing is 4x4 height? You would think with worn springs it would say lower then stock. I thought maybe the rear was sagging but the rear appears to be stock height. Shocks and springs are original from 87. I bought load leveler/towing shocks with springs around them to raise the rear but pretty sure it's as high as it will go. Tires are wrong size as well 225 70 15 but they are junk anyway as date code on em is from 1995. New tread still, car was barely driven in last 23 years.
thread done, as you answered your own question. LOL. I have removed enough original springs with factory sticker tags from different years to know the 87s came that way.
brianb
4
london ,ontario
I got the same problem,,,im thinking wrong springs
87monteSSMN
Nov 20, 2018
74
24
Most guys are saying it's an 87 deal and I'm inclined to believe it. I remember some sitting like this even in the 90s and others not. Reason is the 87s were higher and other years lower I'm guessing now. 245/60/15 out back and 235/60/15 up front helps alleviate this. :)
ed1948
1,286
1,613
Quinte West, Ontario
Pic of my stock 86. The ride height is just under factory spec as measured at the front frame reference point.
