Want soft ride but better handling
Charlyhtx
Apr 10, 2018
59
9
Hey fellas, I've been doing some research but can't really find an answer. I got a 87 Camino, I love the soft ride it has but don't care for the handling. What would be my best options, shocks wise for keeping a soft ride but better handling?
Should I get coil overs or will they make the ride too stiff? Just looking for some guidance here. Thanks
Streetbu
Know it all, that doesn't
3,740
11,593
Central NY
I have RideTech coilovers and 18" wheels. Handles great, definitely has a firmer ride than stock. Only you can decide what is too firm, soft, etc. You can't have handling and a cushy ride, they just don't go together. There will have to be a compromise somewhere. What tire and wheels are you running now or plan on running? That will have an effect on not only the ride and handling, but what some of your other choices should be too.
9,618
12,700
I would say build it for handling but run 15" tires that are relatively tall and wide and then later if you want you can go bigger in rims with a short sidewall and really feel the handling.
Charlyhtx
Apr 10, 2018
59
9
It has 16" iroc wheel now but I plan on putting 18s later down the line
Charlyhtx
Apr 10, 2018
59
9
Also, this is by no means a track car, is it even worth doing tubular control arms or would new stock control arms be fine with coil overs over coil springs?
8,827
7,780
As said, good shocks help both handling and ride quality. As said, start with big sway bars. I can tell you on my Challenger GT rides and stops along with handling even better than our old base Challenger. The base SE was always rougher but the struts were getting really weak after 180,000 km, banging a lot. My 88 Cutlass also is smooth but handles awful, either Challenger or my 70S Cutlass would leave it in the dust on a road course. I did put 4 new Monroe Sensatrac shocks on my 88, it helped quite a bit. I think big sway may be my fix as well.
superbon54
755
2,440
Wisco
Also, look at changing the dynamic camber curve with taller ball joints. Plenty of discussion on how to do it and what fits/doesn’t if you use the search. Good luck!
Umi sway bars any good?
Yes. Something else to consider is the rear Blazer bar as it ties the axle to the frame; the factory bar just ties the lower control arms together.
I saw mention of IROC rims; I'll assume you're running the factory size tire, 245/50-16. I have Xtreme wheels, and am running a 225/60 for a little more sidewall (extra cushy). Of course, that's a moot point if you want to go 18s which is counter-productive to this entire discussion.
