It's not really picked over as much as being roached out. The frame is so bad the rad support mounts ripped from the rad support from them putting them on the wheel stands. It was a 229 base truck with not many options. But there was a good size snake skin behind the glove box.
Bought a trunk load of stuff at the Frog Follies street rod show swap meet a couple of weeks ago. I wanted the seven Q-jets, but the fella wanted it all gone.
Anybody need or want a late'60's/early '70's cast iron Q-jet or mid '60's "Holley" bolt pattern 4Brl sbc manifold?
HP Tuners, the home of VCM Suite and the MPVI since 2003. Now enhancing these to new heights with a new feature rich VCM Editor and VCM Scanner, coupled together with the latest generation MPVI2, this is only tuning and diagnostic solution you’ll ever need for your modern OBDII vehicle.
Picked up a cut to size 8mm ignition wire set (135degree) and vertical stacked looms from Taylor cable. Went with black on both, going for a simple clean look under the hood. Using the stock GM HEI distributor so these will be plenty up to the task.
