full day..
it's done with a push mower and I bag it, make a cleaner job....lost a bit of sweat but that is a good thing.... 🙂
full day..
This also works well, have one at work, gets used a lot. Probably a little spendy for the average guy, though, given it's limited use.
https://www.amazon.com/dp/B000GBLZCU/?tag=gbody-20
girls upgraded from the vette..Misplaced the keys to the wagon... probably a week ago. Just found out earlier today... LOL.
I am very happy with my front and rear sway bars from UMI, and I am sure you will be too. I did not know about the shock tower brace. I think that I will look into that. I also have the rear air bag set-up as well, and am pleased with them too.Okay, so I didn’t actually do all this today, but this is the most recent work I’ve done to Elsie. Since I had some time available and the funds to do it, I installed the basic UMI parts (springs, sway bars, front and rear chassis braces) along with polyurethane isolators to improve Elsie’s handling. While I was at it I also installed a set of Air-Lift bags for when I want to pull a small luggage trailer.
I learned a few new lessons while doing this job. As I don’t have a big compressor to run air tools, I had to compress the springs manually with my biggest 1/2” ratchet. That experience taught me that when I am ready and able to get the UMI control arms and other steering parts later, it will be worth the long drive to Philipsburg and the extra expense to have them do the installation.
The other thing I learned was to never, ever drop a compressed 600 lb/in coil spring on a concrete floor. I had it positioned in the lower A-arm, and then as I reached for a tool or a bolt, the A-arm shifted and the spring fell to the concrete under the car. The compressor unwound with awesome fury, scraping off a good bit of the spring’s heavy-duty coating and making a lot of little chips in the carport.
The third lesson I learned is that UMI’s shock tower brace will not fit with the factory muffler brackets in place. I had not planned to do any exhaust work on the car yet, that’s the next big job, but I had to modify the existing system in order to install the brace. I wound up cutting off the factory pipe in front of the rear axle and using a couple 45 degree elbows to route it out the driver’s side. There’s currently no muffler as I couldn’t see buying one just to throw it away in a few weeks.
When I cut the tail pipe from the original muffler, I found what I believe are chunks of the original catalytic converter.
Here are some photos:
