Well, it ended up being plan or ?? I dug that old mini-blaster out from its place on the bottom shelf on the rolling side table and tried to use fine blast sand to strip the rear end. The only that got blasted was my patience as it did exactly what caused me to dump it in the first place and clogged up, Did some hand stripping using a paint remover and a small hammer while the thunder roared and the rain came down. Then decided to tear down the blaster and see why it kept clogging up. Come to find out that the delivery port between the sand reservoir and the air passage was something on the order of 3/16ths or less in diameter so threw a 1/4 inch drill bit at it to see that would help matters............................and the bit broke.
Got the bit out and finished the oversizing, and put it mostly back together, still have to refit the nozzle. which now needs an oring to seal it. Plan Q is to hand strip all the undercoating that still is present, good stuff that 3M and then go sand for the rust and finish it off with either a wire wheel or an abrasive disk. The end game is to get it as clean and fresh as possible to avoid the return of rust and to give the paint a good surface to grab to.
Looking for a recommendation here. In the while you're there category, while I have the rear end yarded out, it makes the removal of the current shocks a lot simpler.
What I would like to replace them with is a pair of high performance street/road shocks. This car will never see a drag strip or road course but the local streets are mostly ditches to which potholes have been attached. i want a shock that can tolerate being bounced and not bottom out yet not be as hard as a rock. I already have Hotchkiss control arms, c/w polyurethane bushings top and bottom along with the factory anti-sway bar so that much is accounted for. Like that UMI shock tower brace that made a guest appearance above and thinking about braces for the lower control arm mounts on the frame.
Thoughts? Suggestions??
Put the interior back in my car I replaced some of the plastic trim pieces with factory black ones I bought from someone here a long time ago. The ones I didn’t get replacements for I painted with sem color coat. I also put the headliner in and fixed the drivers side seat adjustment wire. The trim pieces were very poorly painted by a previous owner and chipping so it looks a lot better now. The first pics are what the trim looked like before repainting
The Bilstiens are supposed to be the best. The KYB is the popular choice for a premium stock replacement shock.
Received my new power steering pump yesterday, and the new A/C liquid hard line that runs from the condenser to the evaporator arrived today. The hard line looks good, arrived without damage, though I was dismayed at the initial sight of the packaging.
About what it will look like installed.
I was seriously overcharged for S/H @ $70. For 70 bucks it should be stronger and better packaged than this.
No pics of the steering pump, it came in it's original box from Lares, inside another box from RockAuto, with Rockauto's magnet #1.
No working on the non-gbody this weekend. If I can handle the heat wave this weekend, I will be working on installing the A/C condenser and the new power steering pump, maybe also rotate the driver side valve cover 180* with a new gasket (get the oil fill opening toward the firewall), then mount the A/C compressor, and connect the hoses from the air dryer to compressor to condenser to evaporator.
Spend as much as you can on the shocks themselves, they are the brains of the entire operation. Sway bars/ Springs they're just dumb as dirt. they're just follow suit of what the shock is doing. I'm a billstein guy myself,the kyb's are an upgrade from stock.
Showed the car the email from summit that the short block shipped from blueprint today!!! It's only been 69 days since I placed the order.....not that I have been counting or anything 🙂
Calendar GIF by memecandy
some long days rite there..
Unfortunately my wife has been waiting since May 15th for her new washer and dryer, currently the ship date keeps slipping to the far right. At least this gives me time to get the el camino back on the road before I have to play plumber.
Reactions: Texas82GP
