What did you do to your G-Body today?
W
Wageslave
736
483
The Bonneville is on the road!
Got some fluids in it and put enough of the old exhaust on to let it dump out the side, behind the front tires. I took it around the block and it is running pretty good for the most part. I still have a miss that is rocker lash related and I need a different upper radiator hose, but I am pleased at the outcome. Plus, the exhaust sounds awesome. ( if only a little illegal)
motorheadmike
motorheadmike
2,858
3,051
Ottawa, Ontario Canada
Picked up the last batch of hardware removed from the doors and any other stuff I missed earlier
proxy.php?image=https%3A%2F%2Ffarm1.staticflickr.com%2F834%2F43280566902_e165c35596_b.jpg&hash=6e903209b9e3682de95c754c8d07a278
And people wonder why these cars are so heavy. LOL. Looks good!
Texas82GP
Texas82GP
4,371
3,542
Spring, Texas
michmalibuman
michmalibuman
460
329
Hell, half the weight of my G-body is in the drivers seat.:cool:
W
Wageslave
736
483
Got my engine running right and took it for a drive. It freaking rips! Found 2 spark wires swapped and had some sloppy rockers that got adjusted. It freaking rips!
I did learn some stuff today. Such as the oil pressure dummy light does not work if the choke is not hooked up correctly. And for whatever reason, this car came with a temp sensor from a gauges car, so until my gauge cluster arrives I get to judge temperature by how brightly or dimly the light is lit. Also, vortec heads use a different spark plug than non-vortec heads. When I pulled my heads out, I found the spark plugs were recessed back about 1/2 inch out of the combustion chamber. I am guessing that I was losing about half a point of compression to that problem.
Hopefully I will get an exhaust on it this weekend and be on the road again.
Similar threads
