wskirvin
324
423
Indianapolis, In
Finally got it back down on all 4’s front suspension and brakes back together now to turn it around to pull the rearend and redo all the brake lines
Reactions: 7 users
fastNYsix
102
147
Installed new spool fool bumper fillers, they fit great.
Reactions: 6 users
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
The conversion begins
Reactions: 11 users
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
OK quick update.
I highly suggest you use the Blazer brake hoses and brackets
I used the Russell braided lines they are way to long and do not "lock" into the caliper I was afraid with normal driving they might twist over time and come loose.
Now that I was going to use the Blazer brake lines I needed a thread adapter GBody standard Blazer metric
Also you need to install the Blazer brake line bracket and bend the brake hard lines down.
It looks like the line is on top of the A-Arm but it is no where near it. I actually went out and re-checked after I seen this pic.
Also you can see how the Blazer brake hose "locks" into the caliper
Finally with a 15x7 JJ Olds SSII rim you will need a 1/4" spacer for them to fit otherwise the caliper hits the rim.
This is something I was not expecting from the other installs I have seen in the past.
  • Informative
Reactions: 6 users
Ribbedroof
4,904
7,012
Wellston, OK
So, the driver door glass objected to trying out the 29.5x10.5 slicks and nitrous that I just wired in and tied to the trans brake button... (hence the wires I have not put in a loom and tucked under the carpet as it's still in the R&D phase).
Guess I will order some new window felts and weatherstriping and hunt for door glass
If you can't find one locally, I have a pair, assuming it's a Malibu, not a Camino
MrSony
6,831
6,741
Des Moines, Iowa
I put gas in it yesterday, I know my odometer is off either from the gear change, tranmission swap (different speedo gears), or both, it says I drove 80 miles, but only used 1/3 of a tank, but I do know my fuel gauge is accurate. My manual says my car holds 18 gallons, but I've only ever been able to put in 16. I drove the same 1 mile distance (backed up by google maps, was exactly 1 mile distance) in two cars, dad's saturn reads 1 mile, as does google maps. My car reads 1.5 miles in the same distance. If my math is correct (probably not), that means my odo is reading 50% more than a "normal" car. I guess that means if I travel 50 miles in my car, it's actually 25.
SO.
I'm either getting about 15mpg, or 7.5. If it's 7.5, that honestly kinda sucks *ss. It's a bone stock 350 w/ mild cam with a qjet. I'd hope I was at least in the low double digits.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
SO.
get a Garmin and you can check the speedo so you can see how far it's off
KCP
421
1,004
Bavaria, Germany
First start up of the old 305 mill after nearly 6 years. The dealer I bought it from couldn't get her running. I hooked up a cheap electrical fuel pump and jerry can and she fired right up. The 305 will be replaced with my 350 anyway.
  • Winner
Reactions: 5 users
Texas82GP
Just-a-worm
Apr 3, 2015
7,989
18,696
Spring, Texas
SO.
I like this speedometer gear calculator...
http://www.wallaceracing.com/speedo-calculator.php
MrSony
6,831
6,741
Des Moines, Iowa
