What did you do to your non-G body project today? [2019]
mclellan83
4,270
9,487
Pgh, PA
Appreciate it, with my luck I am sure it won't but I guess we will see
Huen79H/O
Jun 5, 2018
74
161
33
Spent the night sweating my marbles off in the garage trying to program that key, stupid GM and their turn the key and wait ten minutes to hear a beep. Low and behold after 2 attempts and much more than 20 minutes I had to give up defeated assuming that the battery is dead in the new fob. Contacted the Ebay seller, he originally said he could refund me or send me a new one. I ask for a replacement and now he has to wait to get a new shipment likely next week
What year make and model are you working on and are you program the key or the fob. I was a service manager at gm for 10 years I might be able to help
mclellan83
4,270
9,487
Pgh, PA
I appreciate it 2004 Pontiac GTO, programming the fob
Huen79H/O
Jun 5, 2018
74
161
33
Well the 04 gto is an animal of its own based from the down under and not like any other gm product and the little dealership I worked at only had a couple in it the whole time I was there sorry I don't have any info for you
mclellan83
4,270
9,487
Pgh, PA
Appreciate the thought, don't think there would be much to do anyway since it is probably a dead battery
Huen79H/O
Jun 5, 2018
74
161
33
You could go to o'Reilly I think they have a fob tester. That would tell you if battery was good and if fob sending out signal. I think those use a watch battery that is pretty easy to change
DRIVEN
8,076
14,543
*CENSORED*
Most dealers keep a RF meter in the service drive thru and test fobs all day long.
mclellan83
4,270
9,487
Pgh, PA
Actually not easy to change the battery, they are soldered on both sides. After some research I am going to make sure that the door was fully shut and try again to see if that is why there is no beeping
81cutlass
4,649
13,565
Western MN
Tooned (turned VATS, some tq. mgmt, and fixed the speedometer) a coworkers LS square long bed. 83 former diesel, now 4.8/60e.
I'm super impressed, he had never done an engine swap before and started last fall. He asked how to do wiring, I said I have HP tuners and he just needs to spend time on LT1 Swap, he did all his own research and work. It's cleaner than anything I have built for sure! Haha
Square people have it EASY, apparently they make LS swap specific exhaust, crossmembers, ECM brackets, use DBW pedals out of a 95ish diesel 2500, all sorts of nice stuff that just bolts in. Makes us G body LS swappers feel inadequate!
117993
117994
Reactions: 12 users
