Oh, yeah, non G Work. Got the second layer of aluminum metal dust laced filler sanded down and threw a top coat layer of Bondo at it. Shaved and sanded that down today using muscle memory and an open tooth body file and a sanding block and identified a few spots that displeased me. Threw a second thin topcoat of Bondo at them. Most of that coat will disappear due to still more block sanding. The plan is to have the panel smoothed and shaped to the point where I can throw a coat of primer at it and then a spritz of black check coat so that I can sand some more and make sure it is flat and curved where it has to be flat and curved. Yeah, yeah, air and power are faster but it is also easier to go too far and remove too much; meaning more has to be added to fix it. If the weather sucks, which it is supposed to, then it will be a slither and slide job under the truck to grab one of the exhaust pipes and deliver it to the welding bench for cleaning and inspection. S-10's don't normally come with true duals; mine did when I bought it but what was a beautiful idea turned out to be a lousy creation. The split head pipes were pure custom fabrication and I have had to revisit that work and do a lot of rehab to it do get them to work right. Along the way I added flanges to them using 3/16ths flat plate with matching plates attached to the cats only with a shoulder included to get them to index into each other. The flanges allow me to remove the cats if I have to take down the whole system for one reason or another. Basically it is now modular. The crippled exhaust section is the one that crosses from the drivers over to the passenger's side. Necessary due to the gas tank being in the road of having it make a straight shot to the rear. Total lack of open territory necessary to do it the easy way.
