It looks like the tank swap is good to go, minus the fact that I need to drive the fuel neck down farther and make a bracket for it. Pump and sender are doing their jobs. The brakes seem alright too, but I need to put the axle on stands and idle the car in gear to see if I have a bent rim or axle. The guys at the dyno said it was jumping pretty good. Hopefully it's just out of balance. Speaking of dyno, I couldn't have picked a shittier day to load and go. I loaded as the snow started coming down which was made even more entertaining by the fact that my knuckle swap netted me 3.5" of toe out which I realized as I got partway down the driveway that was covered in snow so I pressed on to the trailer. I almost didn't didn't make it up between the toe out and snowy ramp with slick tires. Thought I was gonna have to winch it for a second.
I ended up running a space heater in the trailer overnight because the low was 26 and the car has no antifreeze in it.
The only way to open this door the next morning was with a propane torch. I got the ramp door with a prybar and the other side door from the inside with brute force. Had to use 4wd at the gas station because the truck was sliding downhill in park. Everything was a sheet of ice. It was so bad I couldn't position the trailer to fill the car so I filled a jug and hit the road. At the dyno, I ended up having to plate up from a 35mm to a 37mm to get my 260whp, I got 307wtq. Initial pulls on the 35 were 251/301. When I got home I roughed in the alignment at 1/8" toe out. I still need to make sure the rack is centered and get camber evened out on both sides. Leftist good at -3.0 but right side is at -2.7. It's probably close enough but I'll be running counter clockwise next weekend on a rival so the additional camber is welcome on the right side. Once I do that and finish my trap door cover for the fuel tank/pump I should be ready for tech which is scheduled for Tuesday.
