Did probably the most sketchy electrical work, not too proud of that lmao.
As the week before like I said, I didn't disconnect my battery, and the bolt on my alternator touched the block and started a small fire there.
Well, after trying to remove the old alternator cable a few days ago it pulled out the damn positive terminal too. It had welded itself so bad that the threads were destroyed. I am glad I discovered this, because had that terminal got pushed out while driving there could have been another huge fire.
That said, I was able to put in a bigger bolt, and solder wires to it, also because I was nervous about if it would ground to the case or not, I used a LOT of electrical tape.
Also did a voltage test while spinning it up, to make sure it worked. Completed a continuity test too to confirm no short circuit.
I only plan to use this alternator to get me home which is not even a 2 minute drive, and swap it out also.
