What did you do to your non-G body project today? [2022]
I didn't work on anything today. Janet Lauren and I went to bacon fest a a vineyard In New Egypt New Jersey before I slip into my food induced coma I had to show everyone the coolest food truck there REO Speedwagon wood fired pizza oven truck Janet took the pictures while I was looking at it.
I went through and organized my stash of T56 parts since I'm in the middle of building this one up. I've done a few of these over the years, and learned to hang onto this stuff. Sometimes you need that one random small piece. Only thing I've thrown out is busted Keys, trashed Gears, wore out Sliders & Springs, and an excessive amount of stock aluminum 3/4 Forks.
Wanna build one more?
Round 2 of LS1Tech copy/paste. . .
Last night I yoinked the old beat *ss doors and today plucked/gutted/installed the new donor doors. This was already on the agenda, but since lighting the thing on fire crept near the top of the to do list. First off, check out this mish mash of hardware holding the old doors on.
That's a mix of metric and freedom. What a f'in mess. Well I decided to gut doors prior to removal to make them lighter. Here's door #1, took a little figuring out to get here and get it out.
Then I realized that this was not gutted enough, so I gutted the bare minimum to get the windows and sh*t out of the second floor faster in a way where I didn't breathe so much grinding dust.
This came out waaaayy faster than the first. Alright, now that I'm home it's time to remove all that I want while leaving the extra structure that I want in there.
There's the passenger door looking good. The crash bar structure removal was an asspain. Seriously. The asspain cannot be understated.
This pipe is serious.
Seriously heavy. Talk about some schedule 40.
But the damn door won't close.
So even though I scatterbrained gutted the driver's door a smidge more, it turned out to not be enough due to the cage design. Out came the cell phone camera to dial it in.
After buzzing back this entire aft section I had adequate clearance.
So there's the answer to how would I gut a door if I were to gut a door.
I'll probably add a little reinforcement dealie to both sides to stabilize the mirrors.
Yep, that quarter's still fooked.
You can see here why the upper structure had to go.
And here's the passenger side. I kept the black 93 handles to match the black lock cylinders from the donor. Now to get stickers on this thing, it looks like a boring street car now.
Austin trip completed w/o much fuss.
Car did decent for this round of changes (recap: new distributor/wires/coil; rebuilt fuel supply; rebuilt water pump + temp gauge; oil change; new/different wheel & fresh tires). Jr. couldn't sleep the night before so he went to the shop early, yanked the front spring set-up, flattened the main leaf & put it back in the car after leaving a couple of leafs out). That def helped the gap between the fender & top of the tire immensely. Ride wasn't OMG awful but it wasn't good either. It reinforced my original decision to skip the in-between ( '32 front axle + lowered spring combo) & go directly to a 4" dropped axle set-up as it allows for the most spring possible yielding a much better ride quality while still getting it to the ride height we want.
Anyhoo.... The only complications over the weekend were a fuel delivery/vapor-lock issue & cooling system sealing after cruising @ extended speed/rpm for ~30mins (65-75mph). The fuel started to cook in the line & @ the higher rpm the radiator cap could not contain the coolant. Once we navigated off the highway & did ~50mph on service roads there were no issues. It just didn't care for that >70mph for this trip. Next outing (mid June) we'll have a fresh radiator cap seal in place & the fuel line shielded. Oh, and maybe a new Brumfield high-compression head purchased @ the shows swap-meet & a correctly dropped suspension if I can get the front axle in time.
Crazy thing was @ >70mph 'As-Is' Jr let go of the wheel on a stretch of highway & it tracked awesome. We're calling our 'Death Wobble' issue tire related > worn suspension.
So some pics of the additional front drop height & the tug-boat set-up (since I actually cleaned it for the trip).....
As is normal for me, not today, but all recently.
1) Finished my HF trailer
2) Bought a cool old wrist breaker drill motor
3) Fired up my JD 210 garden tractor to till a little patch
