Been working on mattrex past couple weeks. Replaced clutch an pressure plate .hints are take drivers side cv loose at boot then replace boot onto inner joint half with a peice of pine wood 1x2x22"fine if you got axle puller!...people asked me to fix exhaust manifold leak so I replaced gasket between head and exhaust manifold a 2 hour job on a good day...after that the clicking ing in the front control arms has been the result of replacement of both control arms the back bolt can/ was very tight must have been 400 ft lbs I suppose that will wrap the mattrex up .Mentioning here I did a matrex last year yeah control arms ( bushings) it was a 4 wheel drive had some runout on rear differential output I left that one slide...thanks
