what is the best way to STIFFEN a spring without making it taller?
DRIVEN
8,079
14,556
*CENSORED*
A pair/set of springs isn't really that expensive. If you are considering going to the trouble of adding a spacer, why not just replace the springs?
azmusclecar
601
307
I see your point........to open up the control arms and go thru all that I would install new stock height springs.........
I was hoping for a quick inexpensive fix. Thanks for your opinion.
DRIVEN
8,079
14,556
*CENSORED*
I wish there was an easy fix too. My car does the same thing when I'm backing out of a driveway with the wheels turned and hit a bump.
Ribbedroof
4,925
7,063
Wellston, OK
Springs are under a hundred bux on RA..might be the best bang for the buck on these cars
And I agree, as much of a PITA it is to pull the springs for spacers, just replace them while you're in there,
azmusclecar
601
307
Moog 5662s are $45 on RA. You have drop spindles already; do it- you will not be disappointed!
I used your part name and number under Rockauto and it did not come up..............
what search data did you use?
I used 1979 Olds Cutlass Calais 5.7 and all I find is rear coils...............not fronts............
azmusclecar
601
307
Will my Olds, being a Hurst with the 350 CI in it, need any special coils? With the added weight of the 350? Or won't it make that much difference.
I hate to buy OE springs for non H/Os and then come to find out I need heavy duty springs with the weight and suspension set up on the H/O?
My searches seem to just take me to the 305 V8s.............
I am finding a lot of different part numbers checking Federal Mogul and Moog and I can find 305 V8s WITH A/C but no 350 V8s with A/C.
I have used the recommended part number suggested above at Rock Auto and it does NOT come up......for my application.
Not sure what search criteria others are using but I can't find it using mine.
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
When the G Body with stock suspension geometry on the front, (stock height spindles and ball joints) hits a bump or compresses, the tops of the front tires lean out towards the fender (positive camber curve).
On a modern front end set up (like our G Body kits ) the the tops of the tire will "tuck" in out of the way of the fender (negative camber curve).
