yesSo the spacer must go UNDER the spring at the bottom where it sits in the lower control arm?
I see your point........to open up the control arms and go thru all that I would install new stock height springs.........A pair/set of springs isn't really that expensive. If you are considering going to the trouble of adding a spacer, why not just replace the springs?
That's IT EXACTLY..........👍😊I wish there was an easy fix too. My car does the same thing when I'm backing out of a driveway with the wheels turned and hit a bump.
I used your part name and number under Rockauto and it did not come up..............Moog 5662s are $45 on RA. You have drop spindles already; do it- you will not be disappointed!
