Bah, the LS vs Gen1 debate again..
Motorhead Mike hit it on the head. Denmah at Sloppy Mechanics has it down to a science for making LS power on the cheap. He builds some radical stuff on the LS Platform. However 1000+ HP and reliability don't go hand in hand no matter what platform you build off of.
I did the math a few years back.
The "typical" V8 Gbody is powered by a SBC. Your average SBC build on pump gas as a DD will be in the 350-400 hp range and will cost appx $3000.00. Nothing radical, just a used "roller block " vortec motor to be freshened, topped with vortec heads, cam, and headers. Drops right into the car and everything bolts back up. Runs on premium pump gas all done in a weekend.
Typical LS would be a JY 4.8 or 5.3, in the 350-450 hp range ( camshaft and springs ), and the average swap price into a Gbody seems to be $3500 to run carbureted and another $1500+ to retain the FI. Factoring in things like an engine controller, mounts, headers ect and doing most of the fab work yourself with a place to do it as it will take time to sort it all out. Runs on pumps gas with better fuel economy, with a broader torque curve.
As I don't race my car and DD it as much as I can it did not make sense to sink more money and more time to make an additional 100 or so hp. The weekend swap and little to no fab work was also very appealing. Aside from the stereo in my car the only electronics is an O2 Sensor hooked to a wide band gauge helping me keep the carb in tune.
If I were racing or felt the need for more power then the newer technology LS Based engine would be key.
EI: Mutual friend is building a twin turbo 5.3 G. Talking back and forth we figure he should hit the 800hp mark with low boost as he wants to keep it streetable and run the stock hood. Last count I recall he said he was over $8k in parts not including the cost of the car or the orig engine. Its been 3 years and it has not moved an inch.
