NAILS said:pontiacgp: i agree ANY carb can be a descent piece IF money and time is put into it.
bigdan: are you meaning to tell me that you run a STOCK qjet on all of your cars and trucks you described above with just some tuning? if this is the case, i have nothing left to really constructively argue or discuss b/c clearly that is not by a long shot the best carb you can use by a long shot for either application, without emptying your wallet at that. ( the convo was about stock and out of the box/ off the shelf carbs. )
you havent even justified your reason for a carter style carb being out of date. ( which leads me to believe you in fact are ignorant. )
i didnt contradict myself at all... we were talking about unworked stock apps.
anyone can turn junk into a gem with money. send a qjet to john osbourne- one of the most respected carb experts in the usa.
after checking for the horn warping ( and correcting if any is present... which is very common ) inspecting the throttle shafts for leakage ( and correcting it if they do.. which is common as well ), brushing the shafts, if you want it to really run nice- modify the idle discharge ports, upgrade the primary barrels, jetting, i can go on and on. when all is said and done at a carb shop for a GOOD job done right, generally the price is right around $300. to me, 300 is money i could use for a new performer edelbrock, or avenger holley carb.
and yea that q jet will run mint next to either of those carbs - if not better.
