pontiacgp said:if your concerned your pedal travel won't release your clutch here's the measure of a stoke with a 3/4" master cylinder and what travel you'd have at your clutch...
1/2" - .21
1" - .43
1 3/8" - .59
one other thing is that there is a rod that travels from the pedal mounting bolt to the lower bolt for the master cylinder that stops the firewall from flexing. You'll find that rod on an F body standard set up....
Yeah I saw that bracing on the fbody pedals, I may have to fab something up if it seems to be an issue. Does my set-up look similar to how yours is? Is that how your master cylinder is mounted approximately? If 1 3/8" is the amount of stroke that master cylinder has it might be okay...yeah?
