pontiacgp said:I was using an F body pedal that I lengthened 1.5"....I installed everything, set it all up marked it and then took it out to weld a a plate with the pin onto the pedal arm...and found out I didn't like the position of the pedal and the rod for the master looked like it was on an angle so I took it out, cut the plate off and welded it back on....I used a G body brake pedal and just cut the foot plate
why can't you modify the clutch pedal to work with a hydraulic system...all you have to do is to locate the pin in the proper location...
anakputa said:I am in the middle of building my clutch pedal too. I am using the cma39838 clutch master cylinder and Howe Hydraulic Clutch Throwout bearing setup. I bought the pedals of ebay awhile back. I need to make the linkage bracket like this one
http://www.montecarloss.com/ls1montecar ... alBrkt.jpg
Anybody have a template? I don't want to buy another pedal like GSI sells. I have alot of money and time tied up now and am on the home stretch.
What a nightmare so far..Wrong mechanical clutch linkage, it interferes with headers. Wrong type of bell housing, its mechanical.. its turning a money pit..Hope its worth it when I am done..I should have found this site earlier!!![]()
Anyone else use a T-56, there's more info on that. I have a T-5 lets hope it holds up..
Thanks. Yes, it is a 2 piece RMS and needs a 153 tooth flywheel. I'm about to purchase one from an 83 Camaro 305, but it sounds like most pre-86 SBC flywheels with 153 teeth would work..86cutlass383SR said:You want a 153 tooth flywheel for an 84 - 85 Camaro 305.
pontiacgp said:there is a forum out there where they say that you can used the F body pedal set up but that's all wrong...the pedal housing in an F body is not the same as a G body and the F body pedals are 1.5 " too short and are positioned too close to the driver. I used the G body pedal housing with the G body brake pedal and the F body clutch pedal which as I posted I modified it to work. The F body master clutch cylinder fits in the hole in the firewall where the wiring for the cruise control go thru the firewall..and if you can't modify a G body pedal to work then with all due respect find someone else to do the job and pay them
