Which is better, X pipe or H pipe?
I don't understand how you plan on doing this cat back. Now if you plan on true duals w/o cat you will be spending some money. The single exhaust is enough for that engine and a dual system might even hurt performance cause you won't have any exhaust velocity for savaging. If your setting up for a later engine change go for it.
I don't foresee this engine getting any major power upgrades or a complete swap in the near future. It's a single exhaust now, but I do like the look and sound of a dual. If it means I'll lose power, perhaps a Y-pipe out by the very back might work better (just to split at the end leading to two tail pipes)?
The previous owner had custom exhaust done from the headers back on my wagon. It has an X pipe. It was all brand new when I got it. This is the only car I've owned with either an X or an H pipe and it has been a ROYAL PAIN IN THE *ss!!!!!! And is super unnecessary for the stock 350 that feeds it.
In the 18 months I've had the car, I've had to drop the TH 400 transmission twice. I didn't want to have to take loose the exhaust because I know I would only be dealing with leaks later on. I just barely had enough room to slide the G-Force crossmember back far enough to get the trans out and back in.
Getting the driveshaft in and out is almost as tricky. It's a crapshoot between raising and lowering the rear end to make room to slide the driveshaft out the back.
When this exhaust system rots away, and I know it will due to the harsh winters we have here on the Northcoast, and this is a daily/winter beater... it will get stock manifolds back on with true duals and no X or H pipe.
This is why I will never have a car with an H or X pipe. The small gain in any power isn't worth the headache and it seems to tame the sound of the camshaft by tying the sides together.
Reactions: vanrah
The x-pipe on my wagon has to come out to get the transmission out. Thankfully I planned for it by adding v-bands. Still a PITA.
Reactions: melloelky
I like an h pipe with an offset flange so each side is still removable separately. I don't think ill ever have a car with fully welded/one piece exhaust.
