CHEVY Which wire looms to go with
pagrunt
9,168
15,346
Elderton, Pa
In between getting some stuff done & waiting for other parts to show up I'm now looking forward to getting the plug wires cut to fit. I'm just up in the air if I should use what I've used in the past, the old chrome & plastic ones like Moroso & Mr. Gasket makes http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=302870729168 or something somewhat "flasher" like a set of aluminum ones that somewhat matches the O.E. aluminum valve covers http://rover.ebay.com/rover/1/711-5...0001&campid=5335822911&icep_item=331209299866. Even open if there are other options out there.
565bbchevy
9,614
12,683
Michigan
I went with some aluminum separators from Ebay for under $15 for my SBC and I also always get universal wires so I can cut to fit and route them how I want to.
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
On the Olds Iused Moroso wire separators.
On the big Chevy I used
565bbchevy
9,614
12,683
Michigan
On my Monte since the sleeves make the O.D. of the wires so big I made some wire looms out of aluminum sheet and then polished them and then used Rivnuts to mount them to the valve cover.
Streetbu
Know it all, that doesn't
3,734
11,581
Central NY
I used R&M specialties looks. Little bit of a PITA to assemble and get them positioned correctly, but damn they nice once done.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
These are Billet Specialties on the SBC. Like the R&M units their finicky to get set right, but look super clean IMO.....
Reactions: 4 users
paul.m
404
201
I see you have header wraps , some people have concerns with rusting , have you ever seen any sighs of a problem ?
565bbchevy
9,614
12,683
Michigan
For an all season car I wouldn't run header wrap, but for a summer car it works fine and reduces under the hood temps better than any coated headers as long as you properly install it.
