In the pictures the seller had the hood looked like the 77-81 formula scoops... The ones that are basically flat rectangles. I was going to change it for a the 70-75 formula hood... I didn't realize it was the one year only 76 hood which I like a lot so yeah I'm sticking with it. I just need to get it lined up better, the back hits a little on the fender when you open it... And the latch is tricky. Hopefully I can get all that worked out fairly easily. I'm more concerned with getting all the mechanical bugs worked out and winterized before thinking about body work. Hopefully the weather over the winter isn't too bad, so I can get it road worthy by spring... And then really get thinking about the body work.
Main things it needs to be driven is get the brakes working, might just be wheel cylinders and a bleeding... Maybe more who knows. And then figure out what's going on with the power steering... No big deal if it needs a pump, or new lines, that's cheap who cares it works but not well. I don't know why I didn't bother to look before I bought it, but the radiator is also super low... Hopefully it's not leaking big time somewhere, I think this next part might be related I need to replace the heater core, and the blower motor so I have heat at least haha. :lol: I bet the heater core blew and that's where a lot of the coolant went. Good thing I didn't drive it far with it like that.
I don't care for the bird or the shaker hoods much. I like the Mopar shakers, but not the Pontiac ones very much. It actually has white letter BFG's on it, but the letters are facing inside. I think I'm going to replace the tires in the back with ones with a bit more sidewall, maybe gain a little bit more ground clearance so the exhaust doesn't scrape over speed bumps.
