No oil leaks anywhere, and it runs 35-40psi at idle cold, and 25-30 warmed up (idles at around 750 rpm)... And 65+ on the gas warm, almost 80 cold. I kind of want to pull the motor... It's been a long time. Car is off the road minimum of 5 months and the engine bay could use some cleaning up anyway, and since I need to take the hood off to re-align it that's not an issue either.
I thought about using an expandable plug, but I dunno... We'll see when I get around to it. Probably have the motor out over the weekend, and take it to work in the back of my truck and leave it there for the winter. I think I'll pull the oil pan, see if it really has the internals the guy said it has... And pull one of the main caps and look at the condition of the bearings. Plus, should make moving the car around a little bit easier, I think my neighbor is going to let me use his garage over the winter, which is fully equipped with all kinds of air tool goodies and body work tools that I don't have. Different styles of hammers and dolly's, and an amazing array of paint guns, sanders, grinders, wizzer wheels, sheet metal sheers, you name it. And a big like 80 gallon air compressor. :wink:
I pulled the radiator, trans cooler, and fan... And all the engine accessories before work this morning. Tomorrow morning I want to unbolt the headers and remove the carb. I'm not sure if I want to pull the motor AND trans, or just the motor... I think I may be forced to pull the trans there's not much access to the bell housing, it's probably easier to just unbolt the transmission mount and remove the drive shaft. But that's Friday morning's goal is have the cherry picker hooked up and get the motor out or at least ready to go for Saturday.
