work list
thats ok, i got a new one waiting. still in the box.
Good. Don't forget to get a cover for the flywheel/converter too. You don't want stuff bouncing up into that area.
does this look like theres a bolt missing?
between the trans, and the trans mount? :wtf:
Yes, somethings missing... there should be two bolts holding the mount to the tailshaft housing.
Is that vacuum modulator plugged?
It should have a vacuum line running from it to the intake manifold.
yeah, thats the work of the previous owner. fun, aint it :blam:
better get new vacuum modulator..probably shot and sucking fluid out of the trans...
the funnie this is when i first bought the car it wouldnt shift into 3rd no matter what. that why i org. joined gbf. i thought i broke it and everyone screamed yer hoes, yer hoes, and i was like whaaa....?
i found the hoes kinda hangin under the car so i plugged it in the carb and like magic, my trans shifted. :blam:
now i want to replace the timing chain and gear. sooo... i gotta take off the crank pulleys and the radiator before that. well todays payday and imma see what i can get for tommarrow so i can get this beast up and running.
can you tell i am bored at work? :
it has a "T" fitting on it and one side is plugged. i got the new one waiting for the carb to be rebuilt. i should get my carb back next week. then ill start hooking everything back up and get a new alternader and battery, pressureize the oil system, start it up and breaker in. :banana: if my transmission is a th350, what vaccume modulator do i need? say i work for autozone and i know nothing about cars except what the computer says.
:bump:
:bump:
