wrapping interior in black leather
roachownsu
112
2
Ok so me and my buddy are planning on wrapping is 85 monte carlo ss whole interior in all black leather..including the dashboard... is it just easy to use headliner adhesive and wrap it?.. what precautions should I take before doing this project?.. I've never wrapped interior panels with leather.. only seued.. any help would be great
-83MONTESS-
4,570
967
Bellevue, Ohio
All I can say is good luck. I wrapped my A and B pillars as well as the headliner trim pieces and it's already peeling around the edges. I used the high dollar Locktite headliner adhesive from Summit even. It all looked good for a few weeks but now I gotta redo it. It worked awesome on the headliner though :lol:
online170
726
319
I cant help you do the task, but what you are looking to do is NOT crazy, or even out of the ordinary.
I have seen it in Taxi's around here. Everything gets covered (but havent seen the dash done). Headliner, seats, rear deck, floors, trunk, etc... It basically makes it so if someone is sick in your car, you can easily clean it up afterwards and not damage the interior.
If you really want to do it yourself, then so be it. But see if you can talk to an upholsterer. Its not as expensive as you might think. I think the guy who had it done in his car told me it was about $400. Not sure if it was vynil or leather. But it was well done, nice and tight.
WyoKid
194
16
id recommend getting a good spray temp tack. you shouldn't use a adhesive to permanently install new upholstery. it will cause hard spots in the material not allowing for a nice finished product. the temp tack allows you to move the leather or vinyl even after it has been applied.
here is a link to some some one that explains how to do everything properly. i could easily help show you what to do step by step . but this guy does a good job and with pics
http://www.nsxprime.com/forum/showthrea ... The-gluing
he does make the mistake of cutting his material to short at the edges to wrap around. you don't want to do that or you will get raw edges. you should always leave about an inch or to over and then trim the bulk down. better safe than sorry.
as for the dash . that is going to be difficult. there are alot of curves that are going to be hard to get the material to stay, so just take your time and make as little of cuts as possible.
vanrah
879
1,189
Near Afton, Wisconsin
Greetings; Check out my interior viewtopic.php?f=31&t=46801#.VIh7KxSZg5A . I had the plastic covered with vinyl & the front seats with leather. I took the plastic (A B & C) pillars, door panels & what not to the interior guy. That way I saved the RR cost & got all the correct screws back in the correct holes. But the head liner seems to fall every 13 years or sooner. Bob Jr.
L92 OLDS
2,872
3,051
West Michigan
I work for the largest automotive interior supplier in the world and we do leather wrapping in Mexico so we can get away with using solvent based adhesives. Delamination is always a concern and special adhesives are used to prevent it. It's unlikely the industrial adhesives used are available over the counter....
Kiko
300
341
Ottawa, Canada
The interior of my 83 Grand Prix used to be burgundy and now it's all black. What I did was re-painted all the interior plastic trim but covered the dash with leather and the console in suede/leather (see pictures). The original seats were re-covered professionally by an upholsterer since I don't have the required heavy duty sowing machine to stitch leather. For the dash and console, I used an air gun to spray professional grade glue (similar to contact cement), which I purchased from a car upholstery repair shop.
pencero
1,466
25
38
Ind.
I've got a black suede headliner and its holding up nice. I was thinking of doing a few other panels but never the dash. One time I tried to save a dash that was under black leather and it was peeling off it was horrible. There's no going back once that adhesive is all over the dash it's ruined and you have to keep redoing it in leather wrap. That interior paint is definitely the better way to go for the dash...
Kiko
300
341
Ottawa, Canada
If it's done correctly, it'll last a lifetime. My other vehicle (from Germany) has a leather interior which has lasted for many years. The key (IMHO) is to do it once, but do it properly -- use high end glue and good quality material.
