I had a 63 Dodge 440 model and the same thing happened when I replaced the door weatherstrip. Closed the doors and left it out in the Dallas Heat for a weak. Nothing changed. They just dont make them of the same material.
When you say the door gap is off at the top, do you mean the gap between the door and quarter panel, or the gap around the glass?I replaced my weatherstripping on my driver door and body, now the door is hard to close and my top of the door gap is off. How the hell can gaskets ruin my door gap? This car is all original and the door gaps were perfect beforehand. My door pins are fine and my latch is fine
Either way if you replaced the seal that runs up the A-pillar along the underside of the roof and down the B-pillar (the one the glass seals against) you are more than likely going to have to pull the door panel off so you can access the bolts at the adjustment points which allow adjustment of the glass in/out. I’m going to guess you will need to adjust it so it is angled outward at the top so that there isn’t excessive pressure on the glass when the door is closed with the new seal, which is going to be thicker/stiffer and prevent the glass and/or door from closing in the same position as with the old, flattened and worn out sealWhen you say the door gap is off at the top, do you mean the gap between the door and quarter panel, or the gap around the glass?
In my case even with the glass down the door didn't close without excessive force.Either way if you replaced the seal that runs up the A-pillar along the underside of the roof and down the B-pillar (the one the glass seals against) you are more than likely going to have to pull the door panel off so you can access the bolts at the adjustment points which allow adjustment of the glass in/out. I’m going to guess you will need to adjust it so it is angled outward at the top so that there isn’t excessive pressure on the glass when the door is closed with the new seal, which is going to be thicker/stiffer and prevent the glass and/or door from closing in the same position as with the old, flattened and worn out seal
The gap to my quarter panel. The top part of my door where it meets the quarter now sits deeper than the rest of the door. It makes no senseWhen you say the door gap is off at the top, do you mean the gap between the door and quarter panel, or the gap around the glass?
I got it pretty close, I can’t get the glass where it Bends at the a pillar and goes along the roof rail. I just cannot get it to seal. And if I want it to seal better I have to close the door and then roll the window up. And my door to quarter panel on the top of the door now sits in farther it’s weirdEither way if you replaced the seal that runs up the A-pillar along the underside of the roof and down the B-pillar (the one the glass seals against) you are more than likely going to have to pull the door panel off so you can access the bolts at the adjustment points which allow adjustment of the glass in/out. I’m going to guess you will need to adjust it so it is angled outward at the top so that there isn’t excessive pressure on the glass when the door is closed with the new seal, which is going to be thicker/stiffer and prevent the glass and/or door from closing in the same position as with the old, flattened and worn out seal
Metro weatherstripping that goes along the actual door and I forgot the brand of the upper weather strippingSource of the weather stripping? Even .5mm thicker over stock multiplied over several inches adds up.
Double check your install. And double check (compare) your replacement stripping with the old. Somewhere in there you have added to the thickness and door won't close properly, as noted.
I genuinely have no idea how i did it but i got the window to fully seal all the way, room 5 days of messing with itthe aftermarket weather stripping is not so good ... after i got my doors to close good i adjusted the glass the best i could get and could not get it to seal by the roof at all so i took out the weatherstrip on the a pillar and roof moved the channels closer to the door glass and drilled new holes
I'm curious what messing you had to do. What adjustments did you end up making with the glass (I assume) to get the seal better?I genuinely have no idea how i did it but i got the window to fully seal all the way, room 5 days of messing with it
