X pipe
jlcustomz
983
1,096
This is a subject that comes up again & again. Either an x or a h pipe have useful functions such as physically allowing each side of engine to breathe through both mufflers. But it's only a few horsepower, results vary & are better for street or road race than drag race. Either can alter sound for better or worse depending on variables & opinions.
I actually will be trying out 3 in a row later, which with my equal length tri-y headers, should give a sound similar to 180 degree headers by further blending the varying pulses.. I do have stainless v-band fittings to easily take apart though, life doesn't always need to be a fight.
But that's me . I'm just wierd.
  • Wow
Reactions: 7 users
9,617
12,697
I don't care if an X pipe was worth 50 horsepower, I absolutely WON'T have another on any car let alone a daily driver like this car is. Once this system rots away it will be stock manifolds and true duals all the way back.
You just have to design it with a "drop out" section to give you full access to your trans/driveshaft etc.
GuysMonteSS
1,449
1,542
Kentville,Nova Scotia,Canada
This is what I did with my X pipe section.
Made flanges for where it bolts to the tail pipes and the whole X pipe can be out in a couple of minutes.
Guy
8,826
7,779
The compact X pipe made the dual exhaust sound amazing. But most of mine is run under the passenger crossmember hump, so not in the way. Any crossover changes sound but does get in the way.
GuysMonteSS
1,449
1,542
I get a lot of compliments on how good mine sounds.
Guy
Streetbu
Know it all, that doesn't
3,738
11,590
Central NY
If well designed and installed, there is NO reason NOT to have one. It does change the exhaust note, in a good way though.
  • Wow
melloelky
4,167
9,587
mass
they're a pain to work around,i don't think i'd do it again.the v-band's are worthy investment
  • Love
Reactions: 8 users
