Paint pen often comes off with paint thinner or acetone...QC paint pen marks. Sucks they are, as the paint job is pretty sharp.
I might give that a try before I silicone it down.Paint pen often comes off with paint thinner or acetone...
went back and re-read the entire thread, and didn't realize just how much of it I missed.... definitely locked in again, as I'm getting set to get back on the Regal project, and am thinking about this or what Flemming is doing with the pig.... I do also have the 327 with the vortec heads that I'm unsure of the bottom end on.... I know that you were originally looking at the s-10 adapter mounts, but never stated what you eventually used...
side note: late congrats on the wedding, and if you find your way through my neck of the woods in NC, look me up!
Sorry, I'm a little late with this, but here's my thinking on the heater hoses: once, the engine is up to operating temp, most of the coolant flowing around is the same temp, no? That being said, the heater core is just an extension of the coolant loop; the heater control valve will block flow if it is hooked in with the HVAC controls. So, couldn't you just put a pipe plug in the manifold, and just run the hoses to the water pump as originally done? Or, put a sending unit in that hole for a gauge. I think the heater is run off the pump so that it acts like a little radiator until the thermostat opens, creating a little warmth inside the cabin until engine temp rises.
