What did you do to your g-body today 2025 Edition!
Figured since it’s been almost 2 yrs since the last oil change I might as well.. forgot how much it sucks to change it, since the oil filter has been relocated and the 3qt accusump. Then after that debacle it finally got a bath. Before I get hammered about not changing it for 2 yrs it has been sitting in the corner of the shop for about a year. 🙄
No one's going to hammer you about that here, a lot of us are jack stand abusers..
I swapped out my water temp gauge yesterday. The old one was fluctuating between 160* and 240*. After changing the thermostat is when I realized the water temp gauge was the problem. I went with an electric gauge this time instead of a mechanical. It was cheaper but still expensive.
I have that exact aame gauge in my Camaro and I don't like the sweep. It's also tough to gauge where you are between 210 and 250 which is where it lives in the summer. If 180 is your sweet spot then you're good to go. My cooling system can't keep up that well in the dead of summer on a track chasing other cars.
well, the '65 Impala SS convertible in my garage has been sitting on wheel dollies for a "few" years. and the rebuilt 283 SBC from the '67 Impala convertible with about 30 minutes of run time has been on the engine stand for about......28 yrs? yep, that sounds right!
Installed the quadraje tv throttle arm kit for a 200r4 for a 70's q jet and rigged up a bracket using lockar cables for both throttle and detent. Both clear and looks like it's gonna work. Still need to set the adjustment.
Yes they're taller but the flat plastic ridge works better with the speaker panel.
I'm not familiar with those speakers but the NVX speakers I've purchased have that ring as well, but it pops off if you don't want/need it. On mine it's primarily there to protect the cone and surround during shipping but can be utilized for the install if necessary. If you'd prefer shorter speakers it might be worth a wiggle to see if they're removable.
Reactions: MrSony
I don't like the short sweep either. It's kinda hard to tell where your temp is. I will probably bite the bullet and get the same gauge in full sweep. It's about twice the price. $$$
***I'll add it to the list***
Reactions: Sweet_Johnny
Same,the short sweep read on mine's kinda ill viewing and the full sweep's kinda $teep.its not if but when I change it out🤦‍♂️I mean who am kidding
After messing with my other stuff, I figured I would try to start the Monte since we are supposed to have a hot streak over the next week or so. Since it was still pretty cold, she was not happy to start the first time. Gave it a handful of tries and would start but even when trying to gas it to keep it alive it would still stall out, let it sit for a few hours after the first time cause as always the compressor for the air ride had to run for a while so felt like that wasn't helping matters. After letting it sit the few hours, had to give her some gas to keep alive and then high idled for a bit but sat running for a few minutes before the fumes were getting to me even with the garage door open
