Why would you lose the parking brake? Most of the aftermarket base rear disc conversions use the 79-81(?) Seville calipers that have a mechanical pull for the parking brake. Although, Quick charges $55 for it....
www.quickperformance.com
Classic Performance Products offers classic car parts for classic cars & trucks. Shop for performance suspension, brake & steering parts, street performance & restoration components.
www.classicperform.com
You can get an approximation of the d52 bigger bore calipers wilwood sells on the cheap.
Basically on the rear you use the astro van 5x5 rotor, buy a 250 powder coated set of brackets and hardware, and the big bore jd7/jb7 version d52 calipers. Unfortunately, the cheap big d52s with levers largely dried up even as rebuilds being limited to 3 yrs of a submodule late 70s caddy... so it's more pricey (250-400/pr) to get repops.
BUT I was saying for a CHEAP conversion with max stopping power that doesn't cost much money.
This also has you just using the front cross member off a 5 lug 73-87 c10 and having matching calipers/pads/etc all around for easy maintenance.
Guys also make kits using camaro parts, and
impala kits, but those use a smaller setup with less stopping power.
When you've got a 42 or 4500# truck, maybe closer to 5500 with weight in the bed, I'd take all the stopping power I can get.
And if the goal is what can I get, for how cheap can I get it, thats when if no parking brake isn't a concern you can do a massive rear brake conversion for about $300-350 all-in from hoses,plates/brackets,rotors,calipers,pads,hardware,etc is nice
Edit:
Seville appears to use a 2 15//16" piston, which gives a surface area of 6.778in2.
The jd7/jb7 d52 calipers use a single 3-5/16" piston, which gives a surface area of 8.946in2
Thats a good bit more stopping power than the base 80s seville, but, like I said it comes with tradeoffs. You can do it with the rear parking brake, but, it'll add a few hundred to the cost. If that makes sense.
