1984 Oldsmobile Cutlass Supreme Brougham
Very nice, glad to see someone doing a 4 door. I bet that GN suspension sure stiffened it up nicely! Also really like the round gauges you put in and the sport steering wheel. I had to put on 1" spacers as well to fit my rally wheels on the front, the rim would've rubbed on the upper control arm.
Keep up the good work!
Brad
Brad
Thanks!
The stiff suspension actually did reveal a lot of body noises... will need some bracing@!
Going 7 blades on the Cutlass...
Found a copper/brass 4-row radiator from a Camaro...used, for 80$. Cannot pass this one.
I cleaned up the front end :
1) REMOVED - my father had installed an extra electric fan, mounted in front of the radiator, taken from an 80`s car. Came with "home made" dual speed in the form of a gigantic wired round resistor and a couple of relays.
2) REMOVED - an unused trans oil cooler my father had installed in the past, but never connected (for some reason)
3) REMOVED and stored : the A/C radiator.
