1985 Monte SS drag car build
DysonSS
145
281
Littleton NH
That thought did cross my mind. I was thinking of doing a swing out on the drivers side only. I will have to ponder it some more for sure.
lilbowtie
3,460
3,965
Canton Mi
A swing out really isn't going to help, that down bar is just too far forward. Just making a suggestion - if you like the way it is go for it.
bracketchev1221
1,416
1,656
I wouldn't worry about it. The monte has long doors. It won't be that bad. I ran my 70 Chevelle for 20+ years like this.
DysonSS
145
281
Littleton NH
I should be fine... I climbed in and out of one the the bmw drift cars at my work that has a 14 point cage in it just fine this morning and the driver of that car is at least 4” shorter than I am. That is the hardest car to climb in out of the 60+ caged cars we have on our property. Worse come to worse I’ll install a quick disconnect steering wheel. That’s how our full blown rally cars are set up here at work.
DysonSS
145
281
Littleton NH
Got the down bars done and all the structural parts wleded up. I have to mount the seat and fit the door bars and the harness bar next. It’s coming along slowly but surely.
DysonSS
145
281
Littleton NH
Roll cage is done!!! Now the fuel system is next on the list.
DysonSS
145
281
Littleton NH
Finally got quite a bit more work done on the Monte this past couple of weeks. I got the cage all painted up seat mounted and braced to the belt bar. I also got the fuel cell mounted and the 8 an fuel line all plumed up and secure.
DysonSS
145
281
Littleton NH
At least it’s a HV pump 😂. I have had bad luck with Holley electric pumps in the past so I figured I give this a try. When I do the nitrous system I plan on running a 1 gallon fuel cell under the hood with its own electric pump to feed the solenoid.
bracketchev1221
1,416
1,656
First goal is always to get it down the track. Then work on improving it. If you want it to be PERFECT to go to the track, you will never get there. My car was a work in progress for 22 years. Started out going 11.20's and sold going 8.80's.
