BUILD THREAD 1987 Olds 442 Project Build
Now it was time to cut up both bases and hope my calculations were going to work. I knew I needed to cut the entire center section out to make the 2 openings fit. I decided to use 1/4" Pinstriping tape that I bought to use on the SSIII wheels.
This gave me a clear line to follow to help keep my cuts somewhat straight. Cutting an accurate curve with a cut off wheel is challenging under the best of circumstances. The red tape really helped keep me on target.
With both cut out, I cut one end of each so they butt up together.
I tack those in place and take the best base and scribe the marks for cutting my joined pieces to fit back in the opening.
I do my final cuts and tack the whole mess back together.
It fits well, and after I finish all the welding and dressing it should look like it was made that way.
Hutch
Hutch
Nice work Hutch! Looking forward to the end result. Is this air filter housing going to fit under the hood?
Thanks D!!
Not sure yet. I am putting a Hurst Olds hood scoop on, so I may have to open the hood up to get it to fit.
Here's the air cleaner assembled. I had a simulated Olds air cleaner decal made to try to lend a more factory feel.
Hutch
On to something else I've been waiting to do. Install a B&M Quicksilver Shifter in the factory center console.
I didn't have to do any hard thinking because someone else already did. https://buickturboregal.com/quicksilver-shifter-install-buick-grand-national/
The article was very thorough and picture heavy. I just had to follow instructions.
Here's the shifter
I first took some measurements with the factory shifter still in place, so I could have a reference when done.
I had to cut off the front mount flush with the floor per the instructions. I duct taped the shifter in place so I could check the placement with the console on. I wanted to be sure before I drilled holes in the floor.
Happy with the placement, I drilled the holes and got it mounted to the floor. The left side must be shimmed to make it level. I used some slightly larger nuts as spacers.
The back of the shifter butted right to the rear factory mount where it was attached to the floor.
The cable bracket has to be mounted rearward of the intended position to work. The small hole has to be cut open quite a bit as well as the opening on the shifter.
The slider has to be modified to fit the new shifter handle. It also has to clear the bar on the side of the shifter as it will come up through the slider going from park to drive.
The final product is not half bad. It will certainly do in a pinch until I figure out if there's a better way to cover the center where the slider is at.
Hutch
Finally got around to painting the 455 block.
I used some 5/16 bar stock to put the factory pipe plug in for the drivers side oil galley.
With the rear pipe plugs and core plugs installed, I painted the back of the block.
With that done, I cleaned the block well and then used some map gas to sweat any trapped grease and oil out of the porous cast iron.
One more round of cleaning with some acetone and I put on four coats of primer and then put down four coats of color.
I think she turned out quite nice.
Hutch
View attachment 196090 View attachment 196091
Hutch
Your attention to detail is to be commended Hutch.
I watched your YT video on this last weekend. Looks great.
I watched them too. I almost was caught off-guard when Hutch started talking about tarps on the floor and the "Goodfellas" reference. 😆
It seemed like a funny way to end me rambling about tarps. I was going to include DeNiro slamming the phone, but he said f**k so many times I didn't want to do all the editing 😆
Even though in the movie they just let him bleed on the uncovered floor (shoulda had a tarp!)
You're never going to get all that blood out of the grout in that tile!
Hutch
