Re: 1987 Olds Pro-touring project build *LONG*
Few pictures of the roof removal and patch panels:
454muscle said:Shyt bro I hope your water leak issue gets solved. It may be the head gasket but perhaps it could also be the freeze plugs on the underside of the block?
pontiacgp said:sounds like the front bearing seal of the pump is leaking and running down the blades but that leak wouldn't only happen when the pressure builds. Have you removed the belt you can check to see if there is any play and if there is any binding when your turning it?
