He's right.The engine will not set in place in the frame with truck mounts.
Do you have any pics?
Ok. I'm going to see if I can find a s10 and get everythingI used the set up off of a 2000 4.3 v6 s10, Got all the brackets pulleys power steering pump ac comp, tensioner, bolts, and belt for $40.00 off a truck they were parting out on craigslist. I bought a new water pump for a 89 iroc z, and water pump pulley from chevy for around $20 for the iroc.
It works great, and I wasnt out a lot of money.
Do you have any pictureI used a 94 S-10 blazer 4.3l serpentine set for my 82 el c and had the A/C hose made. Other then that no problems. Bent 1 bracket for alternator.
I look up the s10 set on a 94 and a 2000 s10 And the bracket is a little different but thepower steering pump pulley is the same size. So I'm going to start all the way over tomorrow. Going to double check my motor mounts and stuff. To make sure they in the right spotI used a 94 S-10 blazer 4.3l serpentine set for my 82 el c and had the A/C hose made. Other then that no problems. Bent 1 bracket for alternator.
And the pump pulley hits the steering box?
