im leaning towards the vacuum switch, as he said if he taps on the brake pedal it stops the jerking, that means the torque converter in unlocking when the power is cut at the brake pedal switch.
horners85regal said:im leaning towards the vacuum switch, as he said if he taps on the brake pedal it stops the jerking, that means the torque converter in unlocking when the power is cut at the brake pedal switch.
MeanBuicks said:jkey said:MeanBuicks said:The most likely cause is that the TCC (converter clutch) solenoid is stuck which is a very common failure mode for these. Replacement is easy just requiring pan removal and then a couple of 10 mm bolts.
Is there a way to unplug it and see if it is stuck before replacing it? I imagine if its in the pan it wouldn't be worth the time to do that. Wasn't sure if there was an external connector somewhere outside the transmission for it.
Unplugging it electrically will not help when the solenoid fails in this manner. There is an internal check valve in the solenoid that normally bleeds a hydraulic signal off until it is commanded on electrically. What happens is that this valve sticks closed, a mechanical failure, that will exist whether it's plugged in or not. This causes the TCC to apply at all times as the transmission shifts to second gear and beyond. The internal hydraulic signal drops off on the 2-1 shift so that's why the car doesn't stall when stopped even with the solenoid stuck.
