I am going to start with: This is not a thread Hi Jack but a safety bulletin- replace or update the frame..
the Red 80 is before the car on stands and frame is the 86 LS T-Top MC.
1. transmission - 2004R up to 450 HP if built properly
2. TH350 standard transmission up 300-400 Hp no more
3. I see nothing about the Frame Suspension or anything else - speaking from personal experience - putting anything over stock HP in these G Bodies is a recipe for disaster. Torque to rear wheels causes rear end to load on driver side lifting left side and then the rear axle YAW and you have rear wheel steering when not expected,
Repair or replace the FRAME before any HP modifications - going 70 MPH backwards down highway is no picnic...
1. pull frame
2. media blast
3. Box in the Frame
4. put I beam or box cross braces with reliefs for dual exhaust
5. Reinforce the control arms
6. 3/16 steel cross straps in front of shock towers
7. Reinforce the upper control arms with 3/16 steel triangular bosses
8. connect the rear frame rails with a Class III trailer hitch
9. Get a custom rear end from SPOHN Currie or Quick Performance - make it wider than stock with stock mounting points for added stability.
10. then regardless of HP your assured a steady, well handling vehicle without wonky frame torque steering.
11. re-coat - powder coat, Reustoleum black industrial paint or POR 15 then rust coat the insides. I used the Industrial paint and there is no difference from powder coat and cost $50. still looks like new underneath I also rubber undercoat the underside after rust proofing.
12. 4.3 V6 fuel tank from RockAuto and an LS suited pump in tank.
The cross bracing is after these pics- I have a Currie 9 inch with Torino large bearing and all wheel disc brakes
Hope this gives you some ideas since your rebuilding the car anyway...
