2004r wiki edit?
custom442
1,889
5
Houston
On wikipedia it says here:
Unlike the 700R4, the 200-4R has a multicase bellhousing for use with Chevrolet and Buick/Olds/Pontiac/Cadillac (BOP) powerplants. Since the external dimensions are similar to the THM-350, 200-4Rs are usually swapped in place of THM-350s in older vehicles to provide an overdrive gear.
http://en.wikipedia.org/wiki/Turbo_Hydramatic
What basis does this have? That's a terrible swap, nothing will match up from any length tailshaft th350 and the mounting points are different
Anyone have an account to edit that out?
Geesie
364
2
San Diego
I'm not sure what you're complaining about...
Other than a different crossmember, the 200-4R is a direct drop-in replacement for the 350. I just did it for mine a couple months ago and the dual pattern bellhousing and not having to alter my driveshaft were big factors.
custom442
1,889
5
Houston
I was complaining because I thought the driveshaft needed to be changed, but I stand corrected. Also it would lead some people to believe it's a direct bolt in
Some driveshafts can't be used on a trans. that's 5/8" longer. Mine had less than 1" of gap stock and it would have needed to be resized if I went with a 2004r
There's also the issue of having either of the other two tailshaft length 350's besides the short one.
jrm81bu
3,000
48
Antwerp, OH
The g-bodies didn't comw with anything other than the short th350(as far as th 350's go), so if it has a long tail shaft th350 someone has already modified it and the normal rules don't apply.
