2x4 wood car stands
Max Headroom
420
389
Wood beams hold up entire homes when in the process of being lifted off their foundations and moved to a new location.
Personally, I use short lengths of railroad ties to support a vehicle while I'm working underneath. I feel much more comfortable with this method rather than a couple of rickety jack stands.
If you have nothing but solid wood between the frame/tires and the ground....AND the width of whatever you are using is enough to not introduce stability issues..... I don't see the concern.
Wood beams are used to hold up a lot of things, as a temporary measure and I'm not crawling around under any of them. In my opinion, if it ain't steel, it ain't real.
scoti
1,981
3,411
Texas
No guarantee's w/steel either.
Max Headroom
420
389
True but usually with steel, it's designed to hold the weight. Can't be positive about any of it really. There is a post right now about a jack stand recall. That being said, unless it is a 12 x 12, I'm not crawling under anything held up by wood.
87National
663
689
eastern SD
To each their own I guess.....all I know is that the Rail Road ties I use have stood up to years of abuse and tons of weight.....all out in the elements..... Supporting a 3500 lb car??..... no sweat....on the other hand.....a couple of chinese built jack stands??...eh, no thanks.
I will crawl under a car supported by jackstands if I have no other options.... I just pucker up my a_ _ h_le and make it quick :)
ck80
5,743
9,123
If I'm spending time underneath I double up. The car itself goes on stands on all 4 corners to where it's level.
Then I stack 6"x6"x8' PT posts on top of each other perpendicular to the car, up to a height a just couple inches below the body. Stands fail? Lands on the posts which are notched with bolts and two of them are braced for the floor level tier.
Think adult legos.
Dayzedandkonfuzed
971
1,268
Anglemont, BC
When I was an ironworker we used wooden cribbing for everything huge cranes, boilers, generators and more.
I've used "jackstands" built like this. I really need to build another set, anyone who's scared of them has never used them! They are SOLID, no way these are gonna collapse, or kick out, or have 3 out of 4 legs contacting the ground.... I work in the dirt a lot, and jackstands on a soft surface that isn't level scares the sh*t out of me. The cheap ones can even be scary on concrete.
mikester
2,925
3,705
Small town NY
A number of year ago a guy I knew built these. He would put a set of scales on them to weigh the cars he built. Very talented guy. The first time he used them he put a 71 pro touring Chevelle on them. That was before he added the stops. He had them under the front tires, jacked the back up, car rolled forward and the stands damaged the crap out of the floor on both sides when the car rolled off. Needless to say he modified the design.
The guy passed away a couple of years later and a mutual friend of his wound up with them. Lucky for me hes also a mutual friend of mine and lends me these if I need them. They work really well. If I had the extra cash I'd have a set made.
ssn696
Living in the Past
5,548
6,676
Permanent Temporary
