2x4 wood car stands
5spdCab
1,190
1,989
Tukwila, Wa.
Oil change?
scoti
1,979
3,404
Texas
Looks like $50 in steel and a couple of hours with a chopsaw and welder. If it were me, I would connect the legs near the bottom with square tube.
Maybe $50 in used/discarded steel from a steel yards scrap/drop pile. Online steel sources for 2x2x.188 wall sq tube for just 12"L uprights would be @ least $100 & then you have to tie them together like you mentioned w/ either angle or additional sq tube which will add (almost double?) the cost. Still... A good investment for someone that works on projects more than not.
I recently purchased 4qty 8' sections of Unistrut Channel from my local steel yards scrap/discarded pile (Jan '20). By the pound it was over $40 for the purchase so something strong enough to support a vehicle wouldn't have been cheaper.
blk7gxn
1,390
1,886
Found this on Google. Like anything in life, if its done correctly YES! Even steel is dangerous if done incorrectly, obviously there is a recall out there presently!
87National
663
689
eastern SD
I guess it depends on how resourceful you are.
My brother has a business that sells new and used steel (mostly oilfield pipe and rod). He sells new 1.5" square tube for $0.90 per ft and 2" square tube for $1.25. So if I were to attempt to duplicate the stands in the picture, I would do it for around $50. On the other hand if you bought overpriced steel at Lowes.....it might cost $200.
scoti
1,979
3,404
Texas
Local steel yard. Scrapped/drop cuts metal for the Unistrut Channel I bought & it was $45. Not over-priced stuff @ Lowes, Structural stuff would be more than what I paid. I agree it can be possible for the resourceful out there to get things cheaper but where I'm @ you pay by the pound for material.
