KrisW said:You don't want that oil pump kit. This is what they say about THEIR OWN kit:
**TA Performance does not recommend Hi-Volume, Hi-Pressure oil pumps for most combinations due to the increased load they apply to the front of the camshaft. This extra loading can lead to excessive distributor gear and drive gear wear, distributor gear pin breakage, and front cam bearing failure.
You won't need the high volume kit on a Buick. What you need is a thrust plate, and the adjustable pressure regulator:
http://www.taperformance.com/proddetail ... od=TA_1502
http://www.taperformance.com/proddetail ... od=TA_1510
You also need the grooved cam bearing:
http://www.taperformance.com/proddetail ... od=TA_1559
You need to go to the right hand section of the web page at the top, and download the catalog. Then you can cruise it when the internet is off.
I wonder where I got the idea I would need a Hi volume oil pump .. Thanks for the heads up. I just noticed that TA Performance is in Scottsdale, AZ. I might just go have a chat with them 🙂
BTW thanks for the links.
