Just Karter said:Stock ls1s turn 13.80s and 13.90s.
R/T kota said:One example would be my friend stock ls1 98 formula. On the stock tire it was running 13.6 spinning bad, and this was back in 98. Nothing touched on the car at all.
Just Karter said:Just Karter said:Stock ls1s turn 13.80s and 13.90s.
R/T kota said:One example would be my friend stock ls1 98 formula. On the stock tire it was running 13.6 spinning bad, and this was back in 98. Nothing touched on the car at all.![]()
I said STOCKR/T kota said:Just Karter said:Just Karter said:Stock ls1s turn 13.80s and 13.90s.
umm your point?
What ever.
I'll say mine again for you noob
Put a decent street tire on it and was 13.20 all day long. Still no mods.
If a car can run low 13s on a slick, than it does have enough power to run that number now don't it.![]()
Just Karter said:85 Cutlass Brougham said:You are forgetting what is the big drawback to the OE EFI. It will not work properly unless you have the chipped ignition key, and it needs the VSS signal from the trans which also runs the speedo in LSX powered factory installs. it may not even start without the key, as it is a part of the passive anti-theft systems in newer GM cars. The MSD box and carb'd intake is NOT a cheap alternative either. I believe they cost around $800 as a package deal, but it may be a little less or more, I can't find it in my Summit catalog right now. Also, then there's the power steering pump to contend with and custom hoses that will need to be fabbed, the A/C compressor ( which there is no factory way of getting rid of that I am aware of) and it's hoses, if it's a Corvette engine, that is throttle by wire and must be converted, etc. Then there is the electric cooling fans, and upgraded radiator with the right fittings for an LSX. Plus, don't discount the costs associated with the EFI's fuel lines and return lines either. It is in the little things that the LSX is expensive. Yes, you could run a cheap stand alone ECU line the Megasquirt/ Spectre EMS-Pro, or the Greddy Emanage, but those still will cost you a bunch of cash as well ( $300 for a basic Megasquirt, $900 for the EMS-Pro, and around the same for the Greddy). Plus, some of them do not include ignition circuits to run an 8 coil pack ignition, so you need to buy upgrades to do so. I love the LSX engines and wish I could do one for my car, but I see total costs of around $5,000 at minimum, not $2,000 when all is said and done. If you can prove me wrong, fine. Go do it and post the price of every single little part and piece required to make it work properly. I'll admit I am wrong if it can be proven.
^ I need to move in next door and repeatidly tap you for knowledge regularly haha
Good info.
Just Karter said:I said STOCK
Not a SLICK or a high performence tire. Slicks dont come from the factory.
Just Karter said:its 280rwhp for a stock ls1 thats not enough to push a 3400lb car 13 seconds.
Vern said:Karter, I don't care if the thought of reasonable performance AND reasonable mileage in a gbody somehow offends you or.. whatever.
