4L80e Locking dipstick options?
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
Just wondering if anyone has a working dipstick option for a locking 4L80e swap?
Or, will a Lokar dipstick pass tech at the strip? I'd rather do this now since the trans is coming out again.
Tony1968
2,324
5,134
NW Indiana
I've got a GM locking dipstick that I had to bend up a little. It'll work if ya need it
Tony1968
2,324
5,134
NW Indiana
Here you can see it mounted on back of the head. Problem was there wasn't enough room from the firewall when I slid frame back under the body.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
That's the original design, I had to give mine some bending to get it to clear the firewall too.
I'll tell you something. If I had to do it over again I'd want about half an inch more clearance at firewall.
I think Scott has a tad more room than us with his mounts, BMR right Scott? But if its close enough I can make it work... I am not loving the Lokar flexible dipstick.
Tony, have you done poly body mounts? Made a huge difference on my regal for space.
Injectedcutty
G body LS mafia
Nov 24, 2014
6,057
22,811
Louisville, KY
ICT billet swap plates but I'm running 1" setback which is stupid of me. I don't have much clearance back there. Problem is if I move the engine forward the trans mount will miss the crossmember by a cvnt's hair.
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,828
That's about the same as the Holley mounts, 1" back, maybe a tad higher. So itll definitely work for me. Nice!
