So it draws 50 hp and 75 ft/lbs of torque?A fixed fan basically exes out any performance gain you may have realized by putting a 403 in your car to begin with.
Could put an auxiliary electric fan on the front. Use a heavy duty switch to control the relay and source the power from a circuit that's only on with the ignition so if you forget to turn it off then it won't matter.
Can keep a fan that has some concession to economy/performance and give it that little extra cooling capacity when needed without reverting to 1890s technology.
