Fox80 said:Just make sure you consult someone about the ramp, and duration of a hyd. cam. Way to many guys put a fast acting cam with a large duration, that could kill the torque your large inch engine can make. It looks like you have a quality shop that you are using, they should know what to do for your engine. Don't be afraid to have a quality company like Comp. Cams custom grind one for you, the cost isn't much and its worth it. Off the shelf cams are for stock rebuilds or underpowered noise makers. I don't know anything about Pont. but some blocks require machine work for the lifter tie bar to have room to clear.
Oh believe me brother, I'm all about due diligence before I spend a dime and I'm not a young guy just getting started. The machinist is meticulous and knows what he's doing as well. We've kicked around a few ideas so far but nothing is finalized yet. I'm not trying to turn a low grunt engine into a high winding screamer, but everything is getting balanced and I've gone the extra mile for quality machine work. I'm going for a reliable, smooth running street engine with some serious balls when it's said and done.
