Shes a 74 to 79 350 010 with 2 bolt mains & smog heads bud, will suit fine i'm only after a cruiser with this ;-)What's stamped on the flat part of the block protruding from under the passenger side head?
Only on South Park 🤣I was thinking of something else, but came across this when looking for it
Worth a shot at getting it rebuilt? Not sure what cost of one direction or the other would be for you. Unless you got a buddy you can pull a favor from that can rebuild it on the cheap.Well there’s a mega blow & one that will put the Chev running on hold for a while, brand new 3.5k trans stuffed. Had it in the carport covered & she must have sweated. Dought there will be anything salvageable in it, going to drop the engine in & keep setting it up. Will keep going with everything else i can on her & sought a trans when funds allow, lower control arm bushes have arrived so going to pick them up soon. Still waiting on the brakes but thats no biggy, so yeah not a good day but my own fault i should have fulled it with fluid. One expensive lesson learned
Done some research on it & might be able to save it, will pull the valve body down & clean all that up & check what everything else looks like. My fathers rebuilt many over the years so was talking to him last night & watching good old google to see what i'm in for, fingers crossed a good cleanup & service might sort it🤞Worth a shot at getting it rebuilt? Not sure what cost of one direction or the other would be for you. Unless you got a buddy you can pull a favor from that can rebuild it on the cheap.
I think some of the guys on here might be able to point you in the right direction if you need help. Not sure might even be a tech thread on a TH350 rebuilding. Up here I can get a core for about $50 usd but shipping would be killer 😓Done some research on it & might be able to save it, will pull the valve body down & clean all that up & check what everything else looks like. My fathers rebuilt many over the years so was talking to him last night & watching good old google to see what i'm in for, fingers crossed a good cleanup & service might sort it🤞
Should be ok fingers crossed, pulled it down & it hasn't got further up luckily. Got the valve body soaking in that crc evaporust, i'll clean the rest as best I can then chuck her in. I’ll drain it after running it for a bit then refill it., that’ll learn me it should have been in the garage not the carport....I think some of the guys on here might be able to point you in the right direction if you need help. Not sure might even be a tech thread on a TH350 rebuilding. Up here I can get a core for about $50 usd but shipping would be killer 😓
While you have the pan off braze a brass radiator drain bung or if you have a metal bung around put a drain in the back end of the pan. Makes draining it a whole lot easier!😏 couple of junkyard parts for an instant $50 savings!!Should be ok fingers crossed, pulled it down & it hasn't got further up luckily. Got the valve body soaking in that crc evaporust, i'll clean the rest as best I can then chuck her in. I’ll drain it after running it for a bit then refill it., that’ll learn me it should have been in the garage not the carport....
Over here even for a rebuilder your looking at $800 to $1000 for these they're not cheap at all....
